Group: DynoMotion Message: 5737 From: dtplain Date: 10/6/2012
Subject: Dynomotion breaks Mach3 license
I just installed a Kflop/Kanalog setup on a machining center that was setup with Mach3. Since I have a PLC running the toolchanger, spindle, coolant, etc. via Mach3 I'm trying to use the Mach3 front-end.
I have got just about everything working so I wanted to run a test program. The program ran just fine until line 500 when it stopped. Even though I do have a licensed copy and the title bar in Mach indicated that it is licensed it acted as if in demo mode. I figured the license file got corrupted somehow to I copied an archived version into the Mach folder - no difference.
Then I did the brute force approach. Clean install of Mach, re-copy license. Tested Mach and it did recognize more than 500 program lines. Then I re-install Kmotion and Mach would not recognize more than 500 lines. Mach still says it is licensed but operates like it is in demo mode.
Have there been any reports of the Dynomotion plugin breaking Mach3 licenses? Anybody got any ideas on how to fix this?
Dave
Group: DynoMotion Message: 5740 From: Tom Kerekes Date: 10/6/2012
Subject: Re: Dynomotion breaks Mach3 license
Hi Dave,
I haven't heard of this problem.  What version of Mach3 and KMotion are you using?
Group: DynoMotion Message: 5741 From: dtplain Date: 10/6/2012
Mach Version R3.043.044, Kmotion 4.29 (I received the Kflop last week so it should be up to date).
Dave
> Hi Dave,
> From: dtplain <dplain@...>
> Sent: Saturday, October 6, 2012 1:16 PM
> Subject: [DynoMotion] Dynomotion breaks Mach3 license
> Thanks,
> Dave
Group: DynoMotion Message: 5742 From: dtplain Date: 10/7/2012
I did some work on this problem and here's what I've come up with:
My machine is an XP SP3 system stripped down and dedicated to this machine (no internet, adobe products, ...). I even temporarily install an anti-virus scanner to make sure nothing was infected.
The presence of the dynomotion.dll causes the issue. Removing the DLL from the plugin directory corrects the problem moving it back brings the problem back.
It does not matter if the Kflop is connected or not.
I cleared all user programs from the plugin config screen (gave it a dummy init.c) - no difference.
I even tried the development version 4.30z and it does the same thing.
I had a gut feeling this was going to be fun to find.
Dave
Group: DynoMotion Message: 5744 From: dtplain Date: 10/7/2012
I figured it out. If I let Mach ask me each time to select an external motion device it works. If I click "don't ask again" it will not work on the next start up. Don't know why but I can live with that.
I did, however, have a couple of questions about limits.
I have a routine that checks ch0->Dest and when it goes out of limits it sets a virtual bit to represent a limit switch. I have the axis to monitor the bit and inhibit motion into the limit.
if(ch0->Dest > XPLUSLIMIT)
SetBit(48);
ch0->Dest = ch0->Position;
ClearBit(48);
It works okay except that ch0->Dest might be kind of far from the actual limit and trips early (sometimes way early in rapid). I wanted to use ch0->Position but it did not seem to work. Does position not update fast enough while the axis is moving or am I thinking wrong?
Also if the command was for motion beyond the limit I want the proper procedure to clear the command and have the servo hold current position when re-enabled (the ch0>Dest = ch0->Position will jump a little bit).
Dave
Group: DynoMotion Message: 5745 From: Tom Kerekes Date: 10/7/2012
Hi Dave,
Strange.  I just tried it with the Mach3 latest Lockdown V3.043.066 and KMotion V4.29 and I'm not able to reproduce any problem. What I did specifically was:
#1 install Mach3
#2 Install KMotion + Mach3 Plugin
#3 Run Mach3 - mill - Dynomotion Plugin - Dont ask again
#4 configure Dynomotion Plugin
#5 load an example file with 10000 tiny segments forming a circle
#6 Tool plot shows only about 500 segments (fraction of a circle)
#7 Exit Mach3 copy  Mach1Lic.dat to Root of Mach3 Install
#8 Restart Mach3 - plot now shows full circle
#9 Run job - runs all 10000 lines
#10 exit/repeat all seems ok
Regarding soft limit: I don't really understand your description of what is happening.  I believe your system is a servo with encoders so the Position should always match the Commanded Destination (within a few counts) unless you have your setting such that your commanded speed/acceleration is too high for what your system can actually do.  If a small Max Following Error is set then the Commanded and Actual will always be known to be close otherwise there will be a Following Error Disable.  The actual Position always updates every 90us.  I don't really understand the logic of constantly setting the Dest to the Current Position when in the Soft Limit.  There should not be a jump if the system is re-enabled with the Destination set to Current Position.
Group: DynoMotion Message: 5748 From: dtplain Date: 10/7/2012
Yes I've got an digital AC servo system. The motors have 2000 line encoders.
Actually I think the jump is inertia carrying the machine a little further so when when the axis is re-enabled it will do a jump. It's not a large movement about 1/8" or less so it is not a problem.
So on the axis configuration screen if I selected "Disallow drive into limit" or "Kill drive" with the Move0=10000 if the limit "switch" hits at 1000 the drives are disabled and stopped. When the limit is reached Kflop will clear any Dest beyond the current position?
Am I thinking about the Dest correctly? If I command a Move0=10000 does that mean Dest=10000 immediately? Or is the Position supposed to follow an increasing Dest at all times as best as it can? How close should I set a MaxFollowingError?
Dave
> Hi Dave,
> #1 install Mach3
> Sent: Sunday, October 7, 2012 4:43 PM
> Subject: [DynoMotion] Re: Dynomotion breaks Mach3 license
> SetBit(48);
> else
> ClearBit(48);
> Thanks,
> Dave
